Try out Enpass Beta
Enpass Beta lets you play with the newest Enpass features.
macOS (Website Version)
The app itself will notify you about the Beta update as soon as it’s available. To receive the notifications, enable ‘Beta Updates’ from Enpass Advanced Settings.
Requirements: macOS 13 (Ventura) or later
version 6.12.8
macOS (Store Version)
Beta versions for macOS will be distributed through TestFlight.
version 6.12.8
Windows (Website Version)
Requirements: Windows 10 or later
Windows (Store Version)
Beta versions for Windows 10 will be distributed through PackageFlight, so it’s mandatory that you provide your Microsoft Account ID (E-mail) while subscribing for Beta program.
version 6.12.8
Linux
Beta version can be installed directly from the Enpass Beta repository. For more details, please check out this FAQ.
Requirements: Ubuntu 22.04 or later (64-bit only)
version 6.7.2
Chromebook
Beta version can be installed directly from Play Store by joining our Open Beta program or clicking ‘Become a Tester.’
Requirements: Android 9.0 or later
version 6.11.26
Beta versions for iOS will be distributed through TestFlight.
Requirements: iOS 15.7 or later
version 6.11.26
version 6.11.26
Sign Up for Beta Program!
We are currently accepting limited numbers of users to try out our beta version.
