Enpass Beta Release Notes for macOS
Version 6.0.0.250
Release Date Nov 27, 2018
What's New
  • Multiple vaults: This is one of the most demanded features in Enpass that lets you have separate vaults for better segregation of your data. You can create multiple vaults for personal and work data and share with your family or team members by syncing through a common cloud account. However, each of your vaults requires a different cloud account to sync with.
    • To create a new vault, go to app Preferences > Vaults > Click the ‘+‘ icon, and follow the instructions to create your new vault.
  • Custom categories and templates: The desktop version of Enpass 6 now allows you to create your own custom Categories and Templates. This way you can manage your data the way you like.
  • Dark theme: Enpass comes with the dark theme support for Mojave. You need to restart the app after switching the theme from System Preferences for the changes to take effect.
  • Favicons: Enpass 6 can automatically download and set the icon associated with the particular website or URL saved in an item. You can enable it from the Enpass Preferences > Customize > Enable Use Favicon.
  • Custom icons: We've also introduced a much-requested feature; Custom icons, which allows you to set any image as an icon for any item in Enpass.
  • Secure sharing: This version brings secured sharing where you can share an item encrypted with a Pre-Shared Key (PSK). You can create PSK from the Advanced Settings of Enpass after which an additional option to Encrypt with PSK will appear while sharing the item. You need to share the PSK with the intended recipient which he needs to enter while importing the item.
  • Keyfile support: You can now additionally use a Keyfile along with the master password to log into Enpass. Only the desktop versions allow you to generate keyfile while setting up the master password.
  • Trash: Trash is here. From now onwards, every item you delete will go in the Trash first from where you can recover or permanently delete it.
  • Archive: You can archive the items which are no longer in use, but you don't want to delete them as well. The archived item won't appear in any search results.
  • Sorting options: Added options to sort the list of items by Created Time, Modified Time, Recently Used and Frequently Used.
  • Multi-line fields: Added a new field-type as multi-line field which allows you to save information in more than one line. You can make any field a multi-line field by changing its field type from the item edit page.
  • Identity: We've introduced a new default category Identity to let you fill those long, tedious identity forms with a single click.
  • Added localization support for Afrikaans, Malay, Croatian, Hungarian, Indonesian, Romanian, Slovak and Swedish.
Improvements
  • Cloud synchronization: The new Enpass 6 now syncs the Enpass data into the designated App folder on the cloud, unlike it used to do in the root folder for OneDrive, and Google Drive. Along with this, the app now requires minimal permissions and will give relief to our folks who raised concerns regarding the list of permissions the Enpass was asking while configuring the sync, especially in case of OneDrive. Also, as Enpass 6 is based on a new architecture, it will not sync and restore data from previous Enpass 5 and Enpass 6 beta versions.
  • Browser extensions: The new browser extension is now called Enpass Assistant with improved security, auto-filling, and auto-capturing. While setting initial connection, you would need to pair the browser first. It also allows you to autofill in pages with more than two fields.
  • Improved Password generator and strength estimation: We have improved the password generator with the new user interface, option for excluding the symbols and the better strength estimation using zxcvbn. So there might be chances that the password shown as strong in Enpass v5 will be displayed as Weak in Enpass 6.
  • Tags: The erstwhile Folder feature is now known as Tags. All your existing Folders and sub-folders will be replaced by the Tags and sub-tags respectively.
  • Separate section for items with TOTP or Attachments: Many of you folks requested that items with TOTP or attachments should be grouped and displayed together, and here you'll see the separate sections for both TOTP and Attachments in the Sidebar.
  • Eight digits TOTP support: Previously the app was restricted to generate only six digits TOTPs making it difficult for some folks who were using eight-digit TOTPs. Now this limitation has been removed, and you can freely add TOTP to quickly login into accounts.
  • Checking Pwned passwords for the complete database: A significant improvement in checking the pwned passwords! Now instead of checking a single password for pwnage, you can check all passwords saved in your database.
  • Better with importing data from other password managers.
  • A lot of other minor improvements.
Fixes over Previous Enpass 6 Beta
  • There was an issue raised by some of you guys where If a user was adding an attachment containing any language specific characters ( å, ä, ö, etc.), then the app was crashing while saving the item. Well now, Fixed.
  • A bug where WebDAV sync wasn't configuring over the Seafile server, now fixed.
  • Fixed an issue where pressing the ESC key wasn't clearing the search field.
  • Fixed an issue where copying or moving an item from one vault to another, lost all its assigned tags.
