Enpass Beta Release Notes for Android
Version 6.0.0.98
Release Date Dec 5, 2018
Fixes
  • Fixed a bug where some of our users reported that the app was crashing after entering the Master Password.
  • Fixed an issue where the app was crashing on the quick setup page.
  • Fixed an issue where the users were unable to change the app language.
  • Minor fixes and improvements.
Version 6.0.0.93
Release Date Dec 1, 2018
Fixes
  • Fixed an annoying bug that couldn't let the users configure sync on their Android devices.
  • Fixed a bug where the previous beta got crashed while upgrading the Enpass v5 data.
  • In the case of multi-user accounts, installing beta in the secondary account didn't restore the previously loaded data and showed the Welcome screen. Fixed.
  • Fixed an issue where entering some symbols in the search filed made the app to crash.
Version 6.0.0.93
Release Date Nov 27, 2018
What's New
  • Multiple vaults: This is one of the most demanded features in Enpass that lets you have separate vaults for better segregation of your data. You can create multiple vaults for personal and work data and share with your family or team members by syncing through a common cloud account. However, each of your vaults requires a different cloud account to sync with.
    • To create a new vault, go to app Enpass Settings > Vaults and follow the instructions to create your new vault.
  • Favicons: Enpass 6 can automatically download and set the icon associated with the particular website or URL saved in an item. You can enable it from the Enpass Settings > General > Enable Use Favicon.
  • Custom icons: We've also introduced a much-requested feature; Custom icons, which allows you to set any image as an icon for any item in Enpass.
  • Secure sharing: This version brings secured sharing where you can share an item encrypted with a Pre-Shared Key (PSK). You can create PSK from the Advanced Settings of Enpass after which an additional option to Encrypt with PSK will appear while sharing the item. You need to share the PSK with the intended recipient which he needs to enter while importing the item.
  • Keyfile support: Enpass 6 on desktops lets you create and use a Keyfile along with the master password to log into Enpass. If you have added a Keyfile on desktop, you would be prompted to provide keyfile on your device which you can scan from the desktop or load from the Files app in your Android device.
  • Trash: Trash is here. From now onwards, every item you delete will go in the Trash first from where you can recover or permanently delete it.
  • Archive: You can archive the items which are no longer in use, but you don't want to delete them as well. The archived item won't appear in any search results.
  • Multi-line fields: Added a new field-type as multi-line field which allows you to save information in more than one line. You can make any field a multi-line field by changing its field type from the item edit page.
  • Identity: We've introduced a new default category Identity to let you fill those long, tedious identity forms with a single click.
  • Added localization support for Afrikaans, Malay, Croatian, Hungarian, Indonesian, Romanian, Slovak and Swedish.
Improvements
  • Cloud synchronization: The new Enpass 6 now syncs the Enpass data into the designated App folder on the cloud, unlike it used to do in the root folder for Google Drive, and OneDrive. Along with this, the app now requires minimal permissions and will give relief to our folks who raised concerns regarding the list of permissions the Enpass was asking while configuring the sync, especially in case of OneDrive. Also, as Enpass 6 is based on a new architecture, it will not sync and restore data from previous Enpass 5 and Enpass 6 beta versions.
  • Improved Password generator and strength estimation: We have improved the password generator with the new user interface, option for excluding the symbols and the better strength estimation using zxcvbn. So there might be chances that the password shown as strong in Enpass v5 will be displayed as Weak in Enpass 6.
  • Tags: The erstwhile Folder feature is now known as Tags. All your existing Folders and sub-folders will be replaced by the Tags and sub-tags respectively.
  • Separate section for items with TOTP or Attachments: Many of you folks requested that items with TOTP or attachments should be grouped and displayed together, and here you'll see the separate sections for both TOTP and Attachments in the Sidebar.
  • Eight digits TOTP support: Previously the app was restricted to generate only six digits TOTPs making it difficult for some folks who were using eight-digit TOTPs. Now this limitation has been removed, and you can freely add TOTP to quickly login into accounts.
  • While using Fingerprint, many of our users reported of forgetting of the master password making it tough to access their database. Now Enpass give you the option to provide master password after day, week or month.
  • A lot of other minor improvements.
