Using Enpass on an Android Watch
Using Enpass in your Android Watch, you can access selected Enpass Items directly from your wrist, if you already have Wear OS installed on your phone.
To enable Enpass for your Android Watch:
- Install Enpass on your Android phone and your Android Watch.
- Pair your watch with your phone.
- In the Enpass app on your phone, go to Settings > Android Watch, and select Enable Android Watch.
- While on this screen, for your security we strongly recommend creating PIN to unlock the Enpass App on your watch.
Adding and managing Items
To add an Enpass Item to your Android Watch:
- In Enpass on your phone, select the item you want to appear on your phone.
- In the Item Details view, tap ⋮ at the top-right corner, and select Add to Watch.
- Select the fields you want to see on watch, then tap Add.
To view which Items have been added to your watch:
- In Enpass on your phone, go to Browse.
- Find and select Others, then select Watch.
To remove an Item added to your watch:
- Select the Item you want to remove
- In the Item Details view, tap ⋮ at the top-right corner, and select Remove from Watch.
Additional security options available for Enpass in Android Watch
An Android watch works through the Android phone to which it is paired. It communicates securely only with that device, over Bluetooth, using Android Wearable Data Layer API. But Android watches cannot be as secure as your phone (where Enpass protects your data with your Master Password).
Because Android Watch doesn’t have the same level of security as your Android phone...
- Enpass for Android Watch only stores Items that you have specifically selected to appear on your watch.
- For additional security, we strongly recommend creating and requiring a PIN to unlock Enpass on your watch.
- For Enpass Items that include generated one-time codes, Enpass for Android Watch can be restricted to showing only that code, and no other account information.
To create a PIN for unlocking Enpass on your Android Watch:
- In Enpass on your phone, go to Settings > Android Watch, and select Enable PIN.
- Enter a PIN of at least four digits, then tap Done.
To have your watch display only one-time codes for compatible Items:
- In Enpass on your phone, go to Settings > Android Watch.
- Select Show one-time codes only.
